rtm
#1 Posted : Monday, August 18, 2008 9:48:00 AM(UTC)
rtm
purchased and installed kit fountain ice door,which did not fix problem of ice door not opening. Ice dispenses but waits in ice chute for door to open. Could this be a computer board? Thanks.
libertyappl
#2 Posted : Monday, August 18, 2008 1:42:52 PM(UTC)
libertyappl
I would lean more toward the solenoid part #AP3502198
Nat
rtm
#3 Posted : Monday, August 18, 2008 2:38:33 PM(UTC)
rtm
The kit I purchased and installed came with a solenoid. I thought the same thing. Thanks.
libertyappl
#4 Posted : Monday, August 18, 2008 6:41:12 PM(UTC)
libertyappl
If that's the case it almost happens to be the control board.
Nat
rtm
#5 Posted : Monday, August 18, 2008 7:03:13 PM(UTC)
rtm
I'm just a parts changer and I know that it's not going to be a cheap one either thanks for your advise.
rtm
#6 Posted : Tuesday, August 19, 2008 3:48:44 PM(UTC)
rtm
It seems the solenoid is working but still will not open door for ice chute. Is there a roll pin that attaches to the arm to retain the solenoid shaft. I'm i missing a part or did not install it correctly? Thanks.
libertyappl
#7 Posted : Tuesday, August 19, 2008 7:11:28 PM(UTC)
libertyappl
Model Search msd2432gr
CBARTL4306
#8 Posted : Monday, December 1, 2008 1:12:27 PM(UTC)
CBARTL4306
Have Jenair jsd2374ar. Ice Dispenser Not Working. Auger Not Turning But Motot Running. Removed Ice Bin And Re Inserted. Auger Doesnt Turn Even With Bin Empty Of Ice
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
