purchased and installed kit fountain ice door,which did not fix problem of ice door not opening. Ice dispenses but waits in ice chute for door to open. Could this be a computer board? Thanks.
I would lean more toward the solenoid part #AP3502198 Nat
The kit I purchased and installed came with a solenoid. I thought the same thing. Thanks.
If that's the case it almost happens to be the control board. Nat
I'm just a parts changer and I know that it's not going to be a cheap one either thanks for your advise.
It seems the solenoid is working but still will not open door for ice chute. Is there a roll pin that attaches to the arm to retain the solenoid shaft. I'm i missing a part or did not install it correctly? Thanks.
Have Jenair jsd2374ar. Ice Dispenser Not Working. Auger Not Turning But Motot Running. Removed Ice Bin And Re Inserted. Auger Doesnt Turn Even With Bin Empty Of Ice
