phillygirl
#1 Posted : Monday, August 2, 2010 9:58:19 AM(UTC)
phillygirl
I need to replace my heating element. It just lit up and cracked and caught on fire. When I unscrew the two screws to replace it with the new one, the piece does not come out easily. I'm nervous about just pulling it out, and there is some insulation behind the prongs. Can I do this myself, or should I call a profession to install it???????????
ThatGuy
#2 Posted : Monday, August 2, 2010 12:05:08 PM(UTC)
ThatGuy
Groups: Expert
United States
Make sure to unplug the oven before working on the element.
You should be able to pull the element out carefully and get to the connections on the back. Its OK if you pull some insulation out to. Just tuck it back in there later. If your element has the screws holding the wires onto the terminals, use a pair of pliers to hold the new element's terminals while you tighten the screws. You don't want to bend them too much. Good luck.
phillygirl
#3 Posted : Monday, August 2, 2010 2:25:09 PM(UTC)
phillygirl
You said I should unplug the heating element. Unplug? Unplug from where? The only thing that I saw was the two screwsw, which I already was able to unscrew. thanks,
ThatGuy
#4 Posted : Monday, August 2, 2010 2:54:51 PM(UTC)
ThatGuy
Groups: Expert
United States
No, I mean unplug the range or oven. Many ranges have 120 volts to the bake element at all times.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
