LostinMS
#1 Posted : Sunday, August 17, 2008 3:49:16 PM(UTC)
LostinMS
The heat will come on and you can hear a buzz like it's trying to spin but it won't. The belt IS intact. I still haven't really figured out how to get to the motor without tearing up the body. Anyone? :confused:
libertyappl
#2 Posted : Sunday, August 17, 2008 6:45:56 PM(UTC)
libertyappl
You should be able to use a putting knife to relese the clips between the top and the fron panel. Slide the top forward a little and raise it up. There's 2 screws on the top of the panel remove them and lift the front panel off and you can get to everything from there. Check your belt from there. If intact then check your motor and rollers. Post results here.
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
After repair, dryer won't spin with clothes (Dryer Repair)
by skyledavis 8/9/2016 6:39:35 PM(UTC)
Dryer won't spin (Dryer Repair)
by Lovemydog 4/28/2015 6:40:21 AM(UTC)
GE dryer won't spin....except sometimes! (Dryer Repair)
by Cbee78704 11/29/2014 4:13:53 PM(UTC)
Kenmore Dryer won't spin (Dryer Repair)
by Connito 7/29/2014 5:59:09 AM(UTC)
Dryer won't spin fast (Dryer Repair)
by ezfreeze 8/2/2013 9:30:03 PM(UTC)
HELP! Dryer won't spin (Dryer Repair)
by askmelater 10/31/2012 12:43:09 PM(UTC)
Whirlpool Dryer won't spin (Dryer Repair)
by jumbo_rider 4/26/2011 6:24:22 PM(UTC)
Kenmore 98702 Stacked Washer/Dryer won't spin (Washer Repair)
by flashpipe 4/21/2011 5:31:40 AM(UTC)
by mtbikechick1 2/9/2010 3:28:08 PM(UTC)
Dryer Won't spin unless pushed by me (Dryer Repair)
by Rebillbula 4/4/2009 10:38:22 AM(UTC)
by jesco76 4/2/2009 5:45:44 PM(UTC)
by Lingot 1/5/2009 7:19:10 PM(UTC)
by Peter H 11/11/2008 7:56:09 AM(UTC)
