Need your help. My handle broke off at the top. How do you take this handle off and install new handle.
Originally Posted by: Kerry Dalicandro Need your help. My handle broke off at the top. How do you take this handle off and install new handle.
Thanks Sorry for the delay, I recieved a request from our customer service department to review your request. My available information indicates there are several (small) counter sunk screws on the door frame edges around three sides of the door. Remove the screws and then carefully spread the door apart at the handle side, until you can access the door handle screws and remove them. Be careful not to snap or crack the hinge side of the door frame. You may want to install washers under the door handle screws, if there are none when you remove them and do not over tighten the screws,when you replace the handle. If someone else has more or better information, I'm sure they will pass it on to you.
