Hi my name is glenn, Behind cover evaporator #214 (AP2065366) water runs down behind this cover and onto the kitchen floor every two or three days, I believe it happens when the auto. defrost starts. What could be the problem?
Hi Glenn,
There is the drain hole under the evaporator which is clogged and frozen up. Remove the evaporator cover and defrost it, using a hair dryer and hot water to make sure it's clean and open. A turkey baster may help too.
