I set oven temp @ 400 degrees, but then it defaults down to 100 and stays there. What could be the problem? Clock works, burners work...oven doesn't.
Most likely the problem is a bad Bake igniter. Remove the bottom drawer, unplug the igniter and check for 120VAC while the control calls for Bake. If there is 120VAC then replace the igniter. - The part number for the oven igniter is AP205873 Gene.
