botkinlk57
#1 Posted : Saturday, August 9, 2008 3:21:32 PM(UTC)
botkinlk57
I set oven temp @ 400 degrees, but then it defaults down to 100 and stays there. What could be the problem? Clock works, burners work...oven doesn't.
#2 Posted : Saturday, August 9, 2008 10:27:52 PM(UTC)
Most likely the problem is a bad Bake igniter. Remove the bottom drawer, unplug the igniter and check for 120VAC while the control calls for Bake.
If there is 120VAC then replace the igniter.
- The part number for the oven igniter is AP205873
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Maytag Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by debost 1/16/2013 9:46:49 AM(UTC)
Whirlpool Gas Oven will not heat up to desired temperature. (Oven Repair (including Ranges and Cooktops))
by captjob 7/29/2012 5:45:19 PM(UTC)
Double Oven will not heat up past "LOW" (Oven Repair (including Ranges and Cooktops))
by jnichols_1967 2/6/2012 7:52:56 AM(UTC)
Whirlpool Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by stgdobber 5/3/2011 11:19:32 AM(UTC)
Fridgedaire gas range-oven will not heat up (Oven Repair (including Ranges and Cooktops))
by ccjden 3/17/2011 9:52:26 AM(UTC)
by casey114 12/16/2010 11:57:59 AM(UTC)
KitchenAid oven will not heat up... replace thermostat? (Oven Repair (including Ranges and Cooktops))
by Matt M 12/7/2010 11:42:49 AM(UTC)
Oven will not heat up, gas won't flow (Oven Repair (including Ranges and Cooktops))
by spystyle 11/23/2010 3:57:13 PM(UTC)
by hitman401 11/1/2010 1:16:19 PM(UTC)
Dacor Epicure oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jeab 8/10/2010 11:46:30 AM(UTC)
by ar.muncy 3/17/2010 8:47:54 AM(UTC)
Gas Jenn-Air oven will not heat up? (Oven Repair (including Ranges and Cooktops))
by Tony3 12/17/2009 8:04:58 AM(UTC)
