HI, My dryer was working earlier, I did put a larger amount of clothes when it quite. The breaker is ok and I tested the out let 3 prong 220 ok. Went and got a analog meter tried testing all the wires but truth I HAVE NO IDEA WHERE TO PUT THEM. either way I didn't get anything to show on the meter. I only tested the timer and start switch on the back. Do I need to take it apart further? Thanks Paula:(
I got the dryer apart, I've tested the door switch is shows contiv. not sure what all the parts are called but I believe i have tested everything but the motor (there is one in the front on the bottom with 4 quick connections and on on the back at the bottom with 2 quick connections they all have contiv.) In order to get to the motor it seam as though i would have to take the drum off.) Any suggestions any one?????? Paula:)
