lamodj
#1 Posted : Monday, July 12, 2010 8:37:57 AM(UTC)
lamodj
When I go to set the timer on the dryer, there is a humming noise and nothing happens. Usually I can set the timer and then use the starter switch. Will replacing the timer solve the problem or is there more to what could be causing it not to run?
sidfink43
#2 Posted : Wednesday, July 14, 2010 11:28:19 AM(UTC)
sidfink43
Get someone to help you and have them press the start switch while you depress the door switch and manually turn the drum. If it starts up you have the classic symptoms of a bad motor.
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run (Dryer Repair)
by kaostheory09 9/7/2014 1:04:46 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
by paula8315 7/17/2010 6:40:32 PM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
Dryer Will Not Run (Dryer Repair)
by MILTPD 5/5/2010 3:53:45 PM(UTC)
