m123b
#1 Posted : Friday, August 1, 2008 12:00:11 PM(UTC)
m123b
I took apart my washing maching to repair the drum. Now the basket is off center knocks during spin cycle
wendlynb
#2 Posted : Friday, August 1, 2008 12:35:02 PM(UTC)
wendlynb
If the washer is level and springs are properly adjusted then it could need a balance ring. Just a thought.
m123b
#3 Posted : Saturday, August 2, 2008 5:20:55 PM(UTC)
m123b
I think it might be the springs. How do I ajust them. Right now it leans kind of forward and bangs on the spin cycle
wendlynb
#4 Posted : Saturday, August 9, 2008 10:59:17 AM(UTC)
wendlynb
I dont know that they can be adjusted, we always replaced the springs and adjusted the overall balance with the legs. When the springs have proper tention then just attaching them to the holes in the brace would take care of the spring, then we look into the cabinet, and balance ring. Dont forget to always start with the easiest thing which would be an off balance load. A single item can especially a heavy one can throw the load off.
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
Maytag Washer Unbalanced After Tub Bearing & Seal Replacement (Washer Repair)
by Guest 12/26/2022 7:20:26 PM(UTC)
Maytag Bravos Unbalanced Load Problem (Washer Repair)
by Elle Dee 9/16/2019 8:41:38 AM(UTC)
Whirlpool Cabrio WTW6600SB0 - New suspension rods - still unbalanced (Washer Repair)
by kwaropay 8/9/2019 6:13:01 PM(UTC)
Constant unbalanced load error in every setting (Dishwasher Repair)
by JohnRW 9/4/2016 1:31:27 PM(UTC)
UNBALANCED load - Maytag front loader MAH7500AWW (Washer Repair)
by mrogge 10/1/2014 7:40:59 AM(UTC)
Admiral spin unbalanced (Washer Repair)
by fixitright3 11/18/2013 10:00:12 AM(UTC)
Roper washer unbalanced? (Washer Repair)
by jazzinboy175 11/5/2013 5:42:17 PM(UTC)
unbalanced washer constantly (Washer Repair)
by diana7 9/2/2013 10:44:32 AM(UTC)
dryer drum unbalanced (Dryer Repair)
by firefly 9/11/2012 8:57:29 AM(UTC)
Unbalanced spin -- bearing or dampers? (Washer Repair)
by Mike3479 3/12/2012 7:51:46 PM(UTC)
Maytag Neptune Front load very unbalanced (Washer Repair)
by charlie1935 12/28/2011 9:24:59 AM(UTC)
Washer spin unbalanced (Washer Repair)
by peggyirvin5@gmail.com 7/8/2011 7:23:35 AM(UTC)
unbalanced load shuts down washer (Washer Repair)
by skidad 4/25/2011 12:20:10 PM(UTC)
tub goes unbalanced with all loads (Washer Repair)
by lazdina 4/16/2011 9:44:48 AM(UTC)
