Lynn Waddell
#1 Posted : Wednesday, July 7, 2010 8:09:16 AM(UTC)
Lynn Waddell
Dishwasher will not fill. Burned up lower spray arm, have now replaced it and the washer will not fill. What to do?
#2 Posted : Wednesday, July 7, 2010 3:49:22 PM(UTC)
Check that the water valve is getting power when it should (120 volts)
If it is then either the valve is shot or the screen filter on the inlet side of the valve is clogged solid with crud.
Remove the valve from the machine if it is a clogged filter clean it. Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it is not getting voltage check that the overflow switch is activated and closed (0 ohms). Sometimes the float can get stuck in the up position so the unit thinks it is already full with water. In this case remove th float and clean it.
You could measure the voltage across the valve/overfill switch combo (they are wired in series). If there is no power then it could be one of the wires from the control panel is broken or a bad control board. I am speculating here as I cannot find info on this unit.
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
Kenmore Coldspot - Water filter will not fill, no H2O or Ice (Refrigerator & Freezer Repair)
by rncotton 8/16/2023 8:00:22 AM(UTC)
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 8/24/2021 12:55:10 PM(UTC)
Kitchenaid Under Counter Ice Maker will not fill with water (Refrigerator & Freezer Repair)
by Macourt 1/28/2021 11:56:22 AM(UTC)
Kenmore 90 series will not fill (Washer Repair)
by M.O.G.777 3/3/2020 7:34:42 AM(UTC)
GE® 27.8 Cu. Ft. French-Door ice maker will not fill with water (Refrigerator & Freezer Repair)
by MrQuotes 2/10/2019 4:25:01 PM(UTC)
Whirlpool Dishwasher is buzzing and will not fill with water (Dishwasher Repair)
by christyhecht 5/15/2018 9:05:36 PM(UTC)
Water will not fill unless selector is in between settings (Washer Repair)
by Dirka 7/7/2017 10:25:00 AM(UTC)
Maytag 2000 series will not fill on any wash cycle, only rinse cycle (Washer Repair)
by JenBTampa 6/22/2017 7:31:53 AM(UTC)
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 10/7/2016 8:29:08 AM(UTC)
Cold water dispenses, but ice maker will not fill with water (Refrigerator & Freezer Repair)
by mpevans45069@gmail.com 3/6/2016 11:49:08 AM(UTC)
ge washer will not fill error code 10 (Washer Repair)
by Jimverbe 1/28/2016 7:58:07 PM(UTC)
Will not fill on either setting, neither is the machine making à noise when turned on (Washer Repair)
by sparklingblue318 11/20/2015 8:52:36 PM(UTC)
Washer will not fill for Rinse Cycle (Washer Repair)
by KLS2015 6/28/2015 9:05:48 AM(UTC)
Samsung will not Fill or Spin (Washer Repair)
by johndrew 4/6/2015 9:06:07 PM(UTC)
