Hi guys ....having dishwaher probs....when you hit the wash button the light comes on......stays on for a bit (30s-min) than shuts off...dishwaher does nothing.....hoping it's not a control board prob....maybe just has to be reset(I hope).........Cheers :(
Originally Posted by: Gene  I thought if the door switch was bad, I would'nt get any power to the board or panel etc.. I'm prob out to lunch with that idea ...I'll try to check that out...Thanks for the reply.
You are welcome. If there is nothing wrong with the door switches, perform the Service test as instructed in the Tech sheet (page 2). Gene.
