TomFan
#1 Posted : Tuesday, July 6, 2010 8:58:08 AM(UTC)
TomFan
Hi guys ....having dishwaher probs....when you hit the wash button the light comes on......stays on for a bit (30s-min) than shuts off...dishwaher does nothing.....hoping it's not a control board prob....maybe just has to be reset(I hope).........Cheers :(
#2 Posted : Tuesday, July 6, 2010 12:26:28 PM(UTC)
You may want to start the troubleshooting with checking the door switches (part of the door latch - #12 on the diagram). Make sure they are properly engaged when the door is latched.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLD2250RDC4 Frigidaire/dishwasher | AppliancePartsPros.com
TomFan
#3 Posted : Tuesday, July 6, 2010 6:04:38 PM(UTC)
TomFan
I thought if the door switch was bad, I would'nt get any power to the board or panel etc.. I'm prob out to lunch with that idea ...I'll try to check that out...Thanks for the reply.
#4 Posted : Tuesday, July 6, 2010 6:22:26 PM(UTC)
You are welcome.
If there is nothing wrong with the door switches, perform the Service test as instructed in the Tech sheet (page 2).
