ritadi
#1 Posted : Sunday, July 4, 2010 9:30:53 AM(UTC)
ritadi
Checked The Push To Start Switch,and Door Latch Harness,both Good.light Is On.belt Is Good,timer Good????
#2 Posted : Wednesday, July 7, 2010 2:18:09 AM(UTC)
Replacement parts for WHIRLPOOL MED5600TQ0 29" Electric Dryer | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576817.pdf
I am assuming that the light goes off when you push the door switch.
I have a bit of a problem here as the wiring diagram shows a thermal fusr in line with the motor but the parts does not show one.
If it has one it will be mounted on the blower assembly alonng with the cycling thermostat.
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
by jake@studioyoshida.com 11/9/2009 6:28:16 AM(UTC)
