having problem with the evaporator frosting over completly and blocking the air flow i thawed it out last night and its working but the temp in the fridge is 20 degrees and the compressor is still running i have the temp set in the middle position any ideas thanks for any help
Set the freezer temperature control on 2. Wait about 24 hors to see the result. If the problem with the defrost system will come back, you have to have a simple ohmmeter to check the defrost heater and defrost thermostat (#12 on the diagram) for continuity. If there is nothing wrong, replace the adaptive defrost control board (#13 on the diagram). - The defrost heater assembly (the thermostat included) Part number: AP4069790
