ed o
#1 Posted : Tuesday, June 29, 2010 4:14:52 AM(UTC)
ed o
having problem with the evaporator frosting over completly and blocking the air flow i thawed it out last night and its working but the temp in the fridge is 20 degrees and the compressor is still running i have the temp set in the middle position any ideas thanks for any help
#2 Posted : Tuesday, June 29, 2010 1:17:53 PM(UTC)
Set the freezer temperature control on 2. Wait about 24 hors to see the result.
If the problem with the defrost system will come back, you have to have a simple ohmmeter to check the defrost heater and defrost thermostat (#12 on the diagram) for continuity. If there is nothing wrong, replace the adaptive defrost control board (#13 on the diagram).
- The defrost heater assembly (the thermostat included) Part number: AP4069790
- The adaptive defrost control Part number: AP4070403
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool WTW7000WD0 - LED on Mobo Blinking after F5/E2 repair (Washer Repair)
by amofiav 5/6/2024 9:11:07 AM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Need Old Admiral Wiring Diagram (Washer Repair)
by jkuly 1/15/2024 6:09:44 PM(UTC)
replaced auger but ice still not being pushed out of door shoot (Refrigerator & Freezer Repair)
by Guest 10/18/2023 5:41:24 AM(UTC)
Ordered one magnetron, but they sent another (Microwave Repair)
by Demogorgon 9/11/2022 5:14:30 PM(UTC)
in need of a new commercial refrigerator (Refrigerator & Freezer Repair)
by Jake2paul2 8/25/2022 8:48:18 PM(UTC)
Basic things need on Cricket (Trash Compactor Repair)
by Johnalex 7/6/2022 11:07:18 PM(UTC)
new GE range with insulation left in door, burned on use (Oven Repair (including Ranges and Cooktops))
by Hank21 4/21/2022 4:13:03 PM(UTC)
Smells gas as soon as supply is turned on at the wall. (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2022 7:58:00 PM(UTC)
Tiny burner screws sheared off (Oven Repair (including Ranges and Cooktops))
by ADevan 2/19/2022 4:24:24 PM(UTC)
Jenn Air Range spark module keeps sparking with switch turned off (Oven Repair (including Ranges and Cooktops))
by Guest 2/16/2022 11:48:26 AM(UTC)
Jenn-Air spontaneous fire while turned off - JDR8895AAB/S/W (Oven Repair (including Ranges and Cooktops))
by amelanchier 11/1/2021 11:02:50 AM(UTC)
Water and ice locked on front panel Cannot reset (Refrigerator & Freezer Repair)
by bluefitness 9/13/2021 10:47:50 AM(UTC)
