lousdream
#1 Posted : Thursday, July 24, 2008 5:58:31 PM(UTC)
lousdream
Hi I have a kenmore over thats giving us some trouble. The over will not light / heat up . When you set the temp alittle glow light comes on under the over I guess this is like the pilot or igniter ? The over gets warm but never lights up . All top burners are working fine. What do I do now does it need a new igniter or could it be something else ? I have no manule for this over .
Thanks for your help ....
misterfixall
#2 Posted : Friday, July 25, 2008 2:55:55 PM(UTC)
misterfixall
replace ignitor
Kenmore oven reaches set temp but won't stay hot (Oven Repair (including Ranges and Cooktops))
by redhotdaddy 2/4/2024 8:52:11 AM(UTC)
Replacing door on Kenmore oven (Oven Repair (including Ranges and Cooktops))
by gopack 1/15/2019 10:09:12 AM(UTC)
Kenmore Oven Door (Oven Repair (including Ranges and Cooktops))
by wellenreiter 9/29/2016 12:04:11 PM(UTC)
kenmore Oven (Oven Repair (including Ranges and Cooktops))
by gbmitch33 12/31/2015 6:08:07 AM(UTC)
Discontinued Kenmore Oven Part (Oven Repair (including Ranges and Cooktops))
by IbKathy 12/7/2015 4:53:49 AM(UTC)
Kenmore oven temp troubleshooting (Oven Repair (including Ranges and Cooktops))
by Slinger 11/28/2015 4:42:29 PM(UTC)
Kenmore oven temperature issue (Oven Repair (including Ranges and Cooktops))
by Pmacd 11/12/2015 5:16:07 AM(UTC)
Kenmore oven electrial buring smell (Oven Repair (including Ranges and Cooktops))
by snyperj 11/4/2014 4:34:43 PM(UTC)
Kenmore Oven Won't get to temp (Oven Repair (including Ranges and Cooktops))
by Dennis.Powell 6/24/2014 5:01:58 PM(UTC)
Kenmore oven won't self clean - E1 F5 (Oven Repair (including Ranges and Cooktops))
by smammi9 2/28/2014 8:23:23 AM(UTC)
Kenmore oven: stovetop works fine; igniter not heating, even AFTER replacement! (Oven Repair (including Ranges and Cooktops))
by IQpierce 1/2/2014 3:36:02 PM(UTC)
Kenmore oven temperature problem (Oven Repair (including Ranges and Cooktops))
by dro53 9/11/2013 8:17:13 PM(UTC)
Kenmore Oven Stove burner HOT! (Oven Repair (including Ranges and Cooktops))
by sleep 5/14/2013 4:19:35 AM(UTC)
Kenmore oven won't work. Stovetop still works but neither bake nor broil will heat (Oven Repair (including Ranges and Cooktops))
by dangole104 2/18/2013 7:22:38 PM(UTC)
Kenmore oven shutting off (Oven Repair (including Ranges and Cooktops))
by ovenquestion5 1/19/2013 5:06:07 PM(UTC)
