jshoe01
#1 Posted : 18 years ago
jshoe01
The dishwasher runs and never drains (even when I manually cancel/drain). I removed the control module and found a significant burn thru the board near a solenoid?
My question are :
Should I just replace the control module and not worry about it?
Is this a common failure ?
Should I dig deeper to find what caused it ?
If more troubleshooting is required what and how (please)?
#2 Posted : 18 years ago
Hi jshoe01
At this time I would just replace the control board.
This is not a common failure for the Bosch dishwasher.
I would check the resistance though the drain motor terminals. It suppose to be about 16 Ohms.
- Here are the complete troubleshooting instructions for the Bosch dishwasher Model SHU5306 UC/12 (FD 8003-)
- The part number for the new control board AP2802870
Also I would recommend you to check all replies posted by our Bosch guru "loadster".
Good luck.
jshoe01
#3 Posted : 18 years ago
jshoe01
Thanks Gene,
*If* the drain pump is bad, could that cause the solenoid to fry ?
vanhuffel
#4 Posted : 16 years ago
vanhuffel
Hi jshoe01
Good luck.
Perhaps this is not common, however, I have the same symptoms; cycle will not end, but only will drain on cancel-- I have a burned-through pin on the PCB also. On one of the relays. Tried filling with solder, no joy...
#5 Posted : 16 years ago
In such situation the correction is to replace the control module. If you need the correct part number then post the complete model number of the dishwasher.
vanhuffel
#6 Posted : 16 years ago
vanhuffel
I called the toll free number and gave them the model number--it's not one of the covered models in the recall--however they are covering the parts. Thanks
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 6 years ago
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 6 years ago
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 9 years ago
Bosch Dishwasher won't Drain (Dishwasher Repair)
by coachbrady 15 years ago
Bosch dishwasher won't drain (Dishwasher Repair)
by Debbc 16 years ago
by frennings 16 years ago
Bosch dishwasher won't drain after installing new garbage disposal (Dishwasher Repair)
by madden611 16 years ago
Bosch dishwasher won't drain, power surge problems? (Dishwasher Repair)
by vcalkins 17 years ago
by downtube 17 years ago
Bosch Dishwasher won't drain (Dishwasher Repair)
by Little Lost one 17 years ago
by reisman 17 years ago
