jshoe01
#1 Posted : Wednesday, September 5, 2007 5:56:15 PM(UTC)
jshoe01
The dishwasher runs and never drains (even when I manually cancel/drain). I removed the control module and found a significant burn thru the board near a solenoid?
My question are :
Should I just replace the control module and not worry about it?
Is this a common failure ?
Should I dig deeper to find what caused it ?
If more troubleshooting is required what and how (please)?
#2 Posted : Wednesday, September 5, 2007 9:15:43 PM(UTC)
Hi jshoe01
At this time I would just replace the control board.
This is not a common failure for the Bosch dishwasher.
I would check the resistance though the drain motor terminals. It suppose to be about 16 Ohms.
- Here are the complete troubleshooting instructions for the Bosch dishwasher Model SHU5306 UC/12 (FD 8003-)
- The part number for the new control board AP2802870
Also I would recommend you to check all replies posted by our Bosch guru "loadster".
Good luck.
jshoe01
#3 Posted : Thursday, September 6, 2007 9:27:08 AM(UTC)
jshoe01
Thanks Gene,
*If* the drain pump is bad, could that cause the solenoid to fry ?
vanhuffel
#4 Posted : Tuesday, April 28, 2009 4:40:44 PM(UTC)
vanhuffel
Hi jshoe01
Good luck.
Perhaps this is not common, however, I have the same symptoms; cycle will not end, but only will drain on cancel-- I have a burned-through pin on the PCB also. On one of the relays. Tried filling with solder, no joy...
#5 Posted : Wednesday, April 29, 2009 5:02:14 PM(UTC)
In such situation the correction is to replace the control module. If you need the correct part number then post the complete model number of the dishwasher.
vanhuffel
#6 Posted : Wednesday, April 29, 2009 5:19:20 PM(UTC)
vanhuffel
I called the toll free number and gave them the model number--it's not one of the covered models in the recall--however they are covering the parts. Thanks
Guest (5)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
Bosch Dishwasher won't Drain (Dishwasher Repair)
by coachbrady 7/12/2010 6:28:40 PM(UTC)
Bosch dishwasher won't drain (Dishwasher Repair)
by Debbc 4/25/2009 8:25:42 AM(UTC)
by frennings 12/23/2008 2:37:08 PM(UTC)
Bosch dishwasher won't drain after installing new garbage disposal (Dishwasher Repair)
by madden611 11/25/2008 4:05:12 PM(UTC)
Bosch dishwasher won't drain, power surge problems? (Dishwasher Repair)
by vcalkins 8/16/2008 8:41:02 AM(UTC)
by downtube 7/1/2008 4:29:01 PM(UTC)
Bosch Dishwasher won't drain (Dishwasher Repair)
by Little Lost one 6/12/2008 11:30:14 AM(UTC)
by reisman 12/24/2007 7:31:35 PM(UTC)
