fabian
#1 Posted : Tuesday, June 22, 2010 4:49:17 PM(UTC)
fabian
My 2 year old frigidaire washing machine has the lights in the left side of the panel are flickering up and down and sends me an err message but the machine does the entire load even with all of this going on. Once the load is complete the lights on the panel automatically go on again prepared to do another load. The only way I can make the washer turn the lights off is by unplugging it from the electrical outlet. Do you thing there is something I should do before I buy and replace the board?
sidfink43
#2 Posted : Thursday, June 24, 2010 5:02:37 PM(UTC)
sidfink43
Look inside the lower service panel and see if you can locate tech sheets which will explain the error code to you. This should give you some idea if you have to replace the board.
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 8/24/2021 12:55:10 PM(UTC)
Frigidaire Washer FWT449GFS1 won't start or fill will water just makes humming sound (Washer Repair)
by lizard2000 7/6/2021 4:27:51 PM(UTC)
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
Frigidaire Washer FAFW3801LW3 - Just replaced the control board. Washer won't start the cycle. (Washer Repair)
by johnnyboy101 10/4/2019 11:31:42 AM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire washer dispenser magnet (Washer Repair)
by JAbraham 1/19/2016 12:05:33 PM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
Frigidaire Washer error code 31 (Washer Repair)
by tilegods 5/1/2015 4:15:19 AM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Frigidaire Washer "Unique" Leak? (Washer Repair)
by randynavarro 1/3/2015 7:11:35 AM(UTC)
frigidaire washer turns on by itself and floods floor (Washer Repair)
by justin r 12/31/2014 12:32:12 PM(UTC)
