My 2 year old frigidaire washing machine has the lights in the left side of the panel are flickering up and down and sends me an err message but the machine does the entire load even with all of this going on. Once the load is complete the lights on the panel automatically go on again prepared to do another load. The only way I can make the washer turn the lights off is by unplugging it from the electrical outlet. Do you thing there is something I should do before I buy and replace the board?
Look inside the lower service panel and see if you can locate tech sheets which will explain the error code to you. This should give you some idea if you have to replace the board.
