jlamaster
#1 Posted : Monday, June 21, 2010 2:56:22 PM(UTC)
jlamaster
It Doesn't Appear That The Heating Element Is Working. Is It Tough To Replace Or Should I Call A Repair Man?
#2 Posted : Tuesday, June 22, 2010 4:26:32 AM(UTC)
Replacement parts for WHIRLPOOL KUDI01TJWH1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208530866.pdf
[COLOR="Blue"]
Is It Tough To Replace[/COLOR]
Depends what you consider tough.
Unit will have to be pulled out from under the counter at least it will be easier that way.
Also just because it is not heating does not mean that the heater is blown.
The hi-limit thermostat may be blown.
Or it may not be getting power from the control board.
So more troubleshooting must be done before you can say the heater needs replacing. A multimeter is very helpful for this.
Depends on a lot of things so that is a decision only you can make.
jlamaster
#3 Posted : Tuesday, June 22, 2010 5:01:03 AM(UTC)
jlamaster
Thanks denman
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
