clet
#1 Posted: : Friday, June 18, 2010 5:14:58 AM(UTC)
clet
Panel shows cycle time as it counts down. At certain minutes display stops going down and just keeps running at that time. Am I correct in assuming the whole control panel would need to be replaced? I realize that the dishwasher is over 10 years old and if it is the whole panel, a new one might be the asnswer.
#2 Posted : Friday, June 18, 2010 10:37:15 AM(UTC)
Originally Posted by: clet Go to Quoted Post
...At certain minutes display stops going down and just keeps running at that time...
How long time it stays at that point?
How warm is the water inside the dishwasher?
clet
#3 Posted : Friday, June 18, 2010 11:34:42 AM(UTC)
clet
I have waited at least 5 minutes and it doesn't change. Water is very hot, and if the cycle is adding water, it seems to keep adding. (Minute 52) I first noticed this because the dishwasher started to leak, and it had never done that before. Seals are good. I ran a different shorter cycle to see if I could avoid that specific "minute", and no leak, but a stall at a much lower minute happened(6). Do you think that it is heating the water and holding for that?
#4 Posted : Friday, June 18, 2010 12:03:31 PM(UTC)
...Do you think that it is heating the water and holding for that?...
Yes, I do. It should heat up the water and the temperature hold until it reaches the thermostat temperature or it can be up to an hour by default. I could not find the tech sheet for this model and can not tell you what is the exact temperature. It can be from 135°F and up to 160°F.
clet
#5 Posted : Friday, June 18, 2010 3:17:07 PM(UTC)
clet
Thanks, I'll watch for the water temp and see how the timer changes.
#6 Posted : Friday, June 18, 2010 4:41:42 PM(UTC)
P.S. Incoming water suppose to be about 120°F.
dishwasher timer (Dishwasher Repair)
by ppotvin 1/11/2013 4:08:38 PM(UTC)
Maytag Dishwasher Timer won't cycle by itself (Dishwasher Repair)
by datoon1 3/3/2012 1:59:53 PM(UTC)
Kenmore Dishwasher Timer Repair (Dishwasher Repair)
by PHILFMN 1/14/2012 8:42:16 AM(UTC)
Dishwasher Timer (Dishwasher Repair)
by HARRY78 12/13/2011 7:19:32 PM(UTC)
whirlpool dishwasher timer not working (Dishwasher Repair)
by mklittle 4/8/2011 3:12:31 PM(UTC)
Dishwasher timer (Dishwasher Repair)
by Bartc 4/7/2011 3:55:26 PM(UTC)
by djmandyb 3/3/2011 11:59:45 AM(UTC)
Hotpoint Dishwasher Timer Problem (Dishwasher Repair)
by james.hood@yahoo.com 2/13/2011 4:32:30 PM(UTC)
Dishwasher timer has electrical smell (Dishwasher Repair)
by buddyike@sbcglobal.net 9/4/2010 4:58:37 PM(UTC)
Dishwasher timer gets stuck (Dishwasher Repair)
by vince_eeeeh 9/23/2009 1:49:22 AM(UTC)
Dishwasher timer wont count down (Dishwasher Repair)
by Qube85 4/28/2009 5:22:48 PM(UTC)
Maytag Atlantis Dishwasher timer won't run (Dishwasher Repair)
by whytfang 3/29/2009 12:02:24 AM(UTC)
Whirlpool Dishwasher timer -stuck (Dishwasher Repair)
by Trouble in Paradise 8/1/2008 6:06:32 PM(UTC)
