LLIN0321
#1 Posted : Sunday, July 20, 2008 2:22:20 PM(UTC)
LLIN0321
Hello,
Bellow was broken and I fixed it. Machine was working great before. While putting the machine back together the user interface fell down and broke a wire on the end of the ribbon in half. I put it back together but it wouldn't light up right or respond to any command. There is only one horizontal light and no codes . To resolve this problem do I put in a New User interface?
#2 Posted : Monday, July 21, 2008 1:46:18 PM(UTC)
The ribbon is not repairable and you have to replace the user interface to fix the washer.
- The part number for the user interface is AP3128748
Here are the break down diagrams for the Whirlpool Duet washer Model GHW9200LW0
LLIN0321
#3 Posted : Wednesday, July 23, 2008 4:37:24 PM(UTC)
LLIN0321
Hi Gene,
Changed interface. Control locked light on, silk light flashing, 26sec showing and other lights on. Tryed other buttons and turning wash cycle switch no response. Hit cancel/ pause button all lights out and control locked light on, all other lights out. If I press control on and pause/cancel buttons together the above comes back on. Does this mean the CCU is bad?
#4 Posted : Wednesday, July 23, 2008 5:26:09 PM(UTC)
Push and hold the "End of cycle Signal" button for 3 seconds or until it unlocks.
LLIN0321
#5 Posted : Thursday, July 24, 2008 10:07:42 AM(UTC)
LLIN0321
Honorable Gene,
YOU'RE THE MAN!!! Thats it, Works Great! Sincerely, Thank You!
Lou
#6 Posted : Thursday, July 24, 2008 7:29:02 PM(UTC)
You're welcome.
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
