parkerl88
#1 Posted : Friday, July 18, 2008 6:32:54 AM(UTC)
parkerl88
My Kenmore Front Loader will not spin in the final spin cycle. The pump comes on and drains the water, however it will not spin.
I have searched many sites/threads and seem to find that a common problem is the control board going bad. When I look up the parts listing for my washer, there are two boards. One is called control board. It is located in the top of the washer and has all the LED's and buttons attached to it. The other is called control board, motor. It is located in the back bottom right hand corner of the washer.
Each part is >$100 and I dont want to buy the wrong one. The error code I think I am getting is E41 - control board thinks the door switch is open.
I have also come across a wax switch problem on other threads.
Anyone know a way for me to isolate the bad part without wasting money on the wrong part?
fixtec90
#2 Posted : Saturday, July 19, 2008 7:44:53 AM(UTC)
fixtec90
If it's a board it will be the motor controller (the one at the bottom). If the door is locking htat is most likely your problem. You can try to confirm by removing the motor control board. sometimes a resistor will actual burn making the diagnosis a no brainer, but not always. I know I'd feel better about spending the money with a confirmed diagnosis.
If not burned, reinstall board and try the step by step for no motor movement on the touble sheet located in the lower part of hte washer. To do this you will need a volt meter.
parkerl88
#3 Posted : Saturday, July 19, 2008 5:48:31 PM(UTC)
parkerl88
Thanks for the advice. For some reason my particular washer does not have the tech sheet inside of it (this type of luck occurs often with me).
I have seen multiple postings about the door switch; most point out that just because the door is locking, does not mean the switch is functioning properly. Its more than just an open/close circuit.
I found a new switch on ebay for $17. SInce that is the cheapest route, I will try that first. If it does not solve my problem, I will most likely replace the motor control board ( I have inspected it and nothing obvious sticks out).
I will post an update after the switch comes in.
Thanks again for the tips.
parkerl88
#4 Posted : Monday, July 21, 2008 11:18:34 AM(UTC)
parkerl88
I got the switch today. Installed new switch and now I have spinny spinny!
fixtec90
#5 Posted : Monday, July 21, 2008 4:02:31 PM(UTC)
fixtec90
Very nice congrats!
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
by Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
