My range digital lite up with error code "PF" and timer runing, but nothing working. (top burner works normal). Clock and oven not work. OVen light works. Can not cancel the error code from panel or un-plug for overnight. The control is not locked. And the fan turn on when I unplug the midle 4 leg connector from the circuit board (#9760013). What's the problem? Should I replace the Control Panel (P/N:W10122295) or Control, Migration (P/N:9760013)? or other parts or adjustment? I did took apart and clean up and make sure all connector in good condition. Please advise and thanks.
What is the serial number of the range?
PF means power failure. Not sure why it is giving you that error but when the power goes down in my house, my range gives me the PF and I hit clear and that is the end of it.
