johnmou
#1 Posted : Thursday, July 17, 2008 4:16:13 PM(UTC)
johnmou
My range digital lite up with error code "PF" and timer runing, but nothing working. (top burner works normal). Clock and oven not work. OVen light works. Can not cancel the error code from panel or un-plug for overnight. The control is not locked. And the fan turn on when I unplug the midle 4 leg connector from the circuit board (#9760013). What's the problem? Should I replace the Control Panel (P/N:W10122295) or Control, Migration (P/N:9760013)? or other parts or adjustment? I did took apart and clean up and make sure all connector in good condition. Please advise and thanks.
#2 Posted : Thursday, July 17, 2008 7:07:48 PM(UTC)
What is the serial number of the range?
johnmou
#3 Posted : Thursday, July 17, 2008 8:48:17 PM(UTC)
johnmou
S/n:xs1607732
Cabin Guy
#4 Posted : Friday, July 18, 2008 5:25:57 PM(UTC)
Cabin Guy
PF means power failure. Not sure why it is giving you that error but when the power goes down in my house, my range gives me the PF and I hit clear and that is the end of it.
Guest (6)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Samsung induction range oven not working (Oven Repair (including Ranges and Cooktops))
by Wolf22 8/4/2015 12:11:42 PM(UTC)
amana electric range oven not working (Oven Repair (including Ranges and Cooktops))
by jotom55 12/2/2012 8:25:14 AM(UTC)
GE convection range oven not working (Oven Repair (including Ranges and Cooktops))
by kimchalmers 11/26/2012 4:41:43 PM(UTC)
Kenmore Range oven not working (Oven Repair (including Ranges and Cooktops))
by donnalee 8/19/2012 12:52:46 PM(UTC)
GE range oven not working at all (Oven Repair (including Ranges and Cooktops))
by isaac1 7/19/2011 10:54:25 PM(UTC)
Kenmore Range Oven Not Working (Oven Repair (including Ranges and Cooktops))
by swt1221 7/2/2010 4:37:14 PM(UTC)
Frigidaire Range Oven Not Working (Oven Repair (including Ranges and Cooktops))
by aja8888 11/2/2009 11:44:11 AM(UTC)
by aldret 11/18/2008 2:56:52 PM(UTC)
Range Oven NOT Working (Oven Repair (including Ranges and Cooktops))
by johnmou 7/18/2008 7:59:36 PM(UTC)
Electric range oven not working (Oven Repair (including Ranges and Cooktops))
by lightnin 6/24/2008 12:42:46 PM(UTC)
