Had a power problem. Now the clock and oven does not work. All 4 burners work ok and the (burner on) lights work. I do not wish to make an exspensive mistake. Thanks Aldret
THE POWER PROBLEM PROBABLY TOOK OUT THE CLOCK/CONTROL, IF YOUR RANGE IS BISQUE THE PART NUMBER IS AP3461360nAT
Originally Posted by: libertyappl  THE POWER PROBLEM PROBABLY TOOK OUT THE CLOCK/CONTROL, IF YOUR RANGE IS BISQUE THE PART NUMBER IS AP3461360nAT Thanks! Will order part from you site. Aldret
