tcahapw
#1 Posted : 16 years ago
tcahapw
GE Washer, less that three years old, does not spin, agitator cycle works, water drains, lid switch works. Need help? :confused:
#2 Posted : 16 years ago
Does the motor run in spin, if not, just temporaraly bypass the lid switch with a piece of wire.
tcahapw
#3 Posted : 16 years ago
tcahapw
Motor runs, drum doesn't spin, but agitator works
#4 Posted : 16 years ago
Pull the belt off the tranny pulley and turn the pulley in the spin direction. If very ard to turn you either have something stuck in the tub, or bad/seized tub bearings. You can shine a light in the spin basket to look for stuff.
GE washer will not spin (Washer Repair)
by MS104 9 years ago
GE washer will not spin with heavy load (Washer Repair)
by carpe 11 years ago
by Rico Whiskey Delta 12 years ago
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12 years ago
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 14 years ago
GE Washer will not spin (Washer Repair)
by mazdaboss 15 years ago
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 15 years ago
by tcpr12 15 years ago
by bfreeman91080 15 years ago
GE Washer will not spin or agitate (Washer Repair)
by casshley 15 years ago
GE washer will not spin nor agitate (Washer Repair)
by Evans 16 years ago
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 16 years ago
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 17 years ago
by csol147462 17 years ago
