tcahapw
#1 Posted : Friday, June 19, 2009 7:38:23 PM(UTC)
tcahapw
GE Washer, less that three years old, does not spin, agitator cycle works, water drains, lid switch works. Need help? :confused:
#2 Posted : Saturday, June 20, 2009 2:59:14 AM(UTC)
Does the motor run in spin, if not, just temporaraly bypass the lid switch with a piece of wire.
tcahapw
#3 Posted : Saturday, June 20, 2009 7:28:56 AM(UTC)
tcahapw
Motor runs, drum doesn't spin, but agitator works
#4 Posted : Saturday, June 20, 2009 10:19:18 AM(UTC)
Pull the belt off the tranny pulley and turn the pulley in the spin direction. If very ard to turn you either have something stuck in the tub, or bad/seized tub bearings. You can shine a light in the spin basket to look for stuff.
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
GE washer will not spin with heavy load (Washer Repair)
by carpe 11/2/2013 3:08:18 PM(UTC)
by Rico Whiskey Delta 9/21/2013 10:10:40 AM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
GE Washer will not spin (Washer Repair)
by mazdaboss 8/18/2010 6:56:42 AM(UTC)
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 5/11/2010 10:29:14 AM(UTC)
by tcpr12 3/6/2010 6:35:34 PM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
GE washer will not spin nor agitate (Washer Repair)
by Evans 5/18/2009 1:45:06 PM(UTC)
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 3/8/2009 9:44:10 AM(UTC)
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 1/15/2008 3:14:22 PM(UTC)
by csol147462 11/1/2007 7:37:16 AM(UTC)
