herman
#1 Posted : Tuesday, June 16, 2009 9:23:29 AM(UTC)
herman
I have no power to the valve. I checkerd the float swich, ok, also no power toit either. Removed the console checked all the harnesses, tried moveing wires between the door frame. I also put my meter in the inlet valve turning the timer knob no power all I have is motor, I don,t even think I heard the drain solonoid.
thank you for your help
Dave:confused:
Icouldn't find a wiring diagram
#2 Posted : Tuesday, June 16, 2009 11:22:21 AM(UTC)
Hi Dave,
Most likely the problem is a bad push button switch on the Left side of the console.
- The part number for the switch kit is AP2617669
Here are the breakdown diagrams and Replacement parts for GE HDA3220Z07BB | AppliancePartsPros.com
herman
#3 Posted : Wednesday, June 17, 2009 3:20:53 AM(UTC)
herman
There are two switches , pots and pans and normal cycle, can I jump out either of these switches just to be sure.
Thank you
dave
#4 Posted : Wednesday, June 17, 2009 11:11:13 PM(UTC)
That kit includes both switches. As soon as you open the control panel you will see them burned. You do not need any other troubleshooting.
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
