I have read the blog and seem to have narrowed my problem to perhaps the latch. How can I test this? I would like to trouble shoot all the problems before I purchase the part. This is a front loader machine and have not seen this model. Anyother suggestions.
Hi Paul
I do not have a service manual or tech sheet for your model and so do not know of a good way to test the door lock switch. However, the first thing I think you should do, if you have not already, is take off the bottom panel and see if there is a tech document there that will take you through some trouble shooting steps that might help you.
If you cannot reach a satisfactory conclusion, post again with a detailed description of your problem and why you think it is the door switch, and maybe we can offer some suggestions about the diagnosis.
Good luck.
