mark-grace
#1 Posted : Sunday, June 14, 2009 2:00:19 PM(UTC)
mark-grace
My freezer and refrig. are not cooling. The compressor is hot, so I turned it off and unpluged the frig. untill the compressor was cool. I pluged frig. back in, set temp control to the middle (#3) and waited about 45 min. The compressor was again hot and both the freezer and frig. were warm.
I have tested the following and they seam to test SAT:
Starter/overload as
Part Number: AP2114982 made by FRIGIDAIRE
Capacitor, run - Specs: 220 VAC, 15 microfarad
Part Number: AP4315853 made by FRIGIDAIRE
Temp control
Part Number: AP2150703 made by FRIGIDAIRE
Timer, defrost - Specs: 60hz, 120v, 8hr. 30min.
Part Number: AP2111929 made by FRIGIDAIRE
woodchuckie
#2 Posted : Sunday, June 14, 2009 2:51:09 PM(UTC)
woodchuckie
Is the condenser fan running? Are the condenser coils warm?
If yes see if the evaporator coils have any frost or ice on them. Behind the back cover inside the freezer.
mark-grace
#3 Posted : Sunday, June 14, 2009 3:17:03 PM(UTC)
mark-grace
The cond. and evap. coils are not warm. I will check out the fan.
mark-grace
#4 Posted : Sunday, June 14, 2009 3:48:41 PM(UTC)
mark-grace
I checked the fan and it is running. It does not seam tha any air is blowing into the frig. The coils that you are asking about? The one on the back of the frig. about 2' x 3'?
mark-grace
#5 Posted : Sunday, June 14, 2009 4:00:50 PM(UTC)
mark-grace
Woodchuckie
# 15 on dwg 4 Evaporator
Part Number: AP2115142 made by FRIGIDAIRE
# 17 on dwg. 4 Insulator
Part Number: AP2153429 made by FRIGIDAIRE
How do I get to it?
woodchuckie
#6 Posted : Sunday, June 14, 2009 5:17:40 PM(UTC)
woodchuckie
If the condenser coils, which are next to the compressor, are not warm then we need to stop there. Either the compressor isn't doing it's job or the system is low on freon. That's not a diy job.
mark-grace
#7 Posted : Tuesday, June 16, 2009 3:18:29 PM(UTC)
mark-grace
I have checked everything. I called a repaireman today--he said that there is a leak in the freon. He could not find the leak so I bought a new frige. the old one was built 1998.
Problem solved.
Thanks for yopur help with me. I did not know all of the components to test.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
