admoc
#1 Posted : Sunday, December 23, 2007 5:34:09 AM(UTC)
admoc
Sporatic spotting on clothes that does not wash out. I can only assume that the spots are oil. I have checked the tub and found no residue. No dark stains inside washer however mutiple spots appear on clothing from time to time, not consistent. Any ideas??????
abbie
#2 Posted : Sunday, December 23, 2007 6:25:35 AM(UTC)
abbie
ADMOC by any chance are you using liquid fabric softener, if so try not using it for a while and see what happens. if this washer is the older GE washer then it could be the transmission..
admoc
#3 Posted : Sunday, December 23, 2007 6:58:42 AM(UTC)
admoc
We do use liquid fabric softner in our Kenmore. We will try not using it for a few weeks and see if that corrects the problem. Thank you for your reply.
#4 Posted : Sunday, December 23, 2007 12:20:45 PM(UTC)
Pull agitator out and check for oil on the spindle. Some slight oil is normal, but if a lot, you will need a new spindle seal, will have to pull tranny to replace and clean agitator inside.
If your ist 3 numbers of model # are 110, these comments apply, if not please post these numbers.
angry wife
#5 Posted : Sunday, March 13, 2011 5:45:51 PM(UTC)
angry wife
richappy, I read your reply regarding ADMOC's message. Are you referring to the drive tube seals?
Please tell me your advice on my issue:
I have a 1999 Kenmore Series 90 Super Capacity Plus washer (model # 110.26912691)(made by whirlpool). I am getting very intermittent round grease like spots on clothes. I've ruled out the fabric softener theory since mine is removed from the top of the agitator. I removed the complete agitator assembly and noticed grease on the shaft for the splines where the agitator bolts onto it. This I assumed is normal, but also noticed some grease on lower shaft, and on top of the spanner nut which I'm not sure about. If it helps, I also noticed that the white paint is rubbed off the wash basket where it appears that the agitator has been rubbing/sitting on the wash basket exposing the black primer. Any advice is advice is appreciated. I'd attach photo's but know how to on this blog. Jim - j.hoerth@tx.rr.com.
#6 Posted : Monday, March 14, 2011 12:29:03 AM(UTC)
I would pull the tranny, remove the drive block nut and the spin basket, pry off the spindle seal and replace it. Inspect the spin basket for a poor baked on enamel, although rather rare. You will need the special spanner wrench to remove the drive block nut.
Oil spots on clothes (Washer Repair)
by evartsboy73 10/31/2015 9:29:01 PM(UTC)
oil spots on clothes (Washer Repair)
by BW64 5/1/2013 12:36:47 PM(UTC)
by mdiyeso 4/13/2010 11:36:24 AM(UTC)
Kenmore washer with oil spots on clothes (Washer Repair)
by mongo2001 10/20/2009 1:00:00 PM(UTC)
