when it deforse it keeps water in side no place to drian.cant find drip pan i think its pluged but cant find the place it drains.
Part 62 on diagram 10 is your drain trough. > Replacement parts for FRIGIDAIRE FRS22ZGEB0 | AppliancePartsPros.comYour drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
