where is the defrost timer / it seems to not have one / does the pc board act as the defrost timer on this model serial# 9111102757 / model# szde27mw / mfg# p1124401ww
Groups: Expert
Look underneath the front of the unit, thats where the defrost control is located
fridge does not have a defrost control in the front underneath or anywhere else throughout the entire unit instead there is a pc board in the front underneath where the defrost timer should be does this unit use the control board as a defrost timer
