2 Pages12>
mike5017
#1 Posted : Saturday, December 22, 2007 1:26:49 PM(UTC)
mike5017
I have a Kenmore side by side and the ice maker stopped making ice. The bad thing about this is that Sears does not have a diagram of my model with the type of ice maker it has. It seems that my unit has an electronic eye that senses when the ice level in the bin is either low or filled. My ice maker DOES NOT have the old fashion arm that will go up and stop the flow of ice when the bin is filled. My question is, Can the sensor be by-passed (Hardwired)? And does anyone have any information regarding this series of freezers? Again the model number for the unit is 106.50584001
TechnicianBrian
#2 Posted : Saturday, December 22, 2007 5:32:44 PM(UTC)
TechnicianBrian
The unit you have is made by Whirlpool. The first thing you should try is to get your eyes and hands on the black fill tube on the right hand side of the IM and see if its frozen. If it is, take a hair dryer to it and melt the ice. Check the white fingers and make sure they do not move freely, if they spin around, you are looking at a new module. The unit can be wired to force it into a harvest, but let's start with the easy stuff first.
mike5017
#3 Posted : Sunday, December 23, 2007 7:08:15 AM(UTC)
mike5017
Is there a way to check the water flow from the tube once I defrost it. I have the ice maker out and I am free to see and touch the black tube. I want to make sure that I have water flow before I put the unit back in.
PS. The white fingers on the ice make DO NOT spin freely. Thanks
TechnicianBrian
#4 Posted : Sunday, December 23, 2007 10:00:09 AM(UTC)
TechnicianBrian
Was the tube frozen? If so defrost it and put everything back together and give it some time. It is best to let it cycle back on itself. If the tube was clear, then I will need you to do the electrical checks.
mike5017
#5 Posted : Sunday, December 23, 2007 10:20:33 AM(UTC)
mike5017
I checked the black hose and it was not frozen. Water is flowing to the door, however not as fast as it use to. Could there be a clog in the water feed that is not giving any pressure to the ice maker? Any thoughts?
TechnicianBrian
#6 Posted : Monday, December 24, 2007 9:43:35 AM(UTC)
TechnicianBrian
Sorry for the late reply, the water pressure should not be an issue, but more likely a failure of the electronics, the IM module assembly, or even the IM thermostat. Start by tapeing the freezer light switch and the IM sensor closed so the electronics think the door is closed. Take the cover off the IM and look for two holes labels T and H. You can place a jumper wire (use insulated pliers to insert it) between these two points then give it a few minutes to see if it begins to cycle. Another thing to try, unplug the whole IM and look at the wire harness. You should measure 110vac between white and black/white. If you are carefull and you have the 110vac, you can touch a jumper wire between black/white and the tan wire and the fill valve will turn on (be quick or you will get everything wet). Let me know what you find out.
These checks require interaction with live power and the use of a meter in a confined space. If you are unsure of your abilities or are uncomfortable doing these tests, DO NOT DO THEM! Being shocked by your refrigerator has little enjoyment potential.
Tim H.
#7 Posted : Monday, December 24, 2007 11:11:24 AM(UTC)
Tim H.
Technician Brian
Sorry to intrude but I'm having a similiar problem as posted below. I have checked between black and white and I'm only getting 99.8 to 100 volts. Any thoughts??
mike5017
#8 Posted : Tuesday, December 25, 2007 5:58:31 AM(UTC)
mike5017
Well, well, well. I removed the IM and tested for power by using my VAC meter. I get nothing. I know the VAC meter works cause I tested it in a normal outlet. It looks like I am not even getting power to the unit, but I am getting power everywhere else. Where do I go from here? (I did tape the door light and ice sensor switches closed):mad:
TechnicianBrian
#9 Posted : Wednesday, December 26, 2007 7:29:53 AM(UTC)
TechnicianBrian
If you have nothing at the IM connector, looks like a sensor board failure. Check a couple more times just in case the sensor 'wakes up'. If nothing, remove the three screws on the sensor board, remove the board and jumper between the black wire and the black/white wires next to each other. You are bypassing the sensor doing this and should then read 110vac at the IM connector. Reconnect the IM, jumper between 'T' and 'H' and the unit should start a harvest cycle. Remove the jumper after the fingers have dropped below the white stripper fingers and see if everything else works. If all works, your sensor boards need replacing.
When placing jumper wires, remember to be careful and pay attension. The wire connector to the sensor board has live voltage all the time the refer is plugged in.
mike5017
#10 Posted : Friday, December 28, 2007 4:07:00 PM(UTC)
mike5017
Can you point me in the right direction? Where would this sensor be located? I don't have a parts list, or a unit diagram which shows where it is. I will test it, just let me know where it is. Thanks
Guest (11)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
2 Pages12>
