Yes i could sure use some help here with a pdf of my model or things to check for.Everything works fine but lost the heat on wash and dry cycles, no heat period.Wife also says been sticking on cycles not sure on that. Thanks and greetings from the rainy PNW.
THIS FORUM IS DEAD!!!!!!! |
Denman
I have replaced element and still no heat wash or dry cycle.Could i jump the hi temp thermostat in heat cycle? i got a 0 ohm reading while disconnected.Reading on old heat element was 13.8 ohms on bench afraid i tested on 20k scale and got 0 ohms and ordered new one which is not the problem.Any help would sure be appreciated Thanks Denman
Could i jump the hi temp thermostat in heat cycle? i got a 0 ohm reading while disconnected. Yes you could but I doubt it will make any difference as it measured 0 ohms at room temperature.
I would check the wires from the timer to the heater perhaps one of them is broken. If the wires are OK then the most likely culprit is the timer. The timer's heater contacts are probably shot. |
