acuevas
#1 Posted : Tuesday, June 2, 2009 4:59:00 PM(UTC)
acuevas
Hey All,
Concerning above mentioned washer. I was doing a bit of troubleshooting and removed the drive pulley. I started to replace the drive pulley but, for what ever reason, I don't have enough of the shaft sticking out to put on the retaining washer and clip. Any suggestions are most welcomed.
#2 Posted : Wednesday, June 3, 2009 8:03:56 AM(UTC)
I would go to the web site, www.applianceaid.com for correct washer replacement info. Important you get the washers in the right order.
I have read you can stick a throw pillow on top of the agitator and force the lid down with a heavy object, this will force the spindle down to allow washer replacement. Post reults.
acuevas
#3 Posted : Wednesday, June 3, 2009 10:53:49 AM(UTC)
acuevas
Sorry, but I have tried all that I have been advised and I am not able resolve this issue. I looked at the diagram to make sure all the washers are correctly aligned and cam properly set. It is if the shaft became shorter suddenly. Is there a way to release the shaft? :(
#4 Posted : Wednesday, June 3, 2009 2:06:35 PM(UTC)
Re-post your problem, maybe someone has more experience.
Tight drive pulley after bearing replacement (Washer Repair)
by maverick 5/24/2017 9:48:04 AM(UTC)
Replacing the drive pulley on a Duet Dryer (Dryer Repair)
by rkeranen 7/14/2015 6:02:55 AM(UTC)
GE drive pulley grinding (Washer Repair)
by Nick Good 12/7/2014 8:11:02 PM(UTC)
Replacement Drive Pulley for Maytag Performa (Dryer Repair)
by dsuper11 9/8/2012 9:01:54 PM(UTC)
kenmore dryer drive pulley (Dryer Repair)
by nsoron2@att.net 4/28/2012 6:18:48 AM(UTC)
Drive Pulley (Washer Repair)
by TOM VITAZ 10/19/2011 3:11:54 PM(UTC)
change drive belt and drive pulley (Washer Repair)
by clacker48 3/8/2010 8:27:42 AM(UTC)
drive pulley falls off (Washer Repair)
by daddd 2/1/2008 5:43:03 PM(UTC)
