billfvib
#1 Posted : 16 years ago
billfvib
iT TAKES A LONG TIME FOR THE OVEN TO HEAT UP. tHE RELAY ON THE CIRCUIT BOARD TURNS ON AND OFF. wHEN ON 240 VOLTS ARE GOING TO TOP ELEMENT AND ONLY ABOUT 50 TO THE BOTTOM. iT STAYS OFF A LONG TIME BEFORE COMING BACK ON FOR ONLY A FEW SECONDS.
#2 Posted : 16 years ago
SOS - Frigidaire Electric Range not working (Oven Repair (including Ranges and Cooktops))
by Pete11 10 years ago
Frigidaire Electric Range F3 fault code (Oven Repair (including Ranges and Cooktops))
by utahmom 11 years ago
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 12 years ago
frigidaire electric range (Oven Repair (including Ranges and Cooktops))
by PITMAN 13 years ago
Frigidaire Electric Range - Oven just blew - Top works HELP (Oven Repair (including Ranges and Cooktops))
by Kris&Tara 14 years ago
changing ECU in frigidaire electric range.. quick question (Oven Repair (including Ranges and Cooktops))
by larryk13 15 years ago
Frigidaire Electric Range-- controller 'brains' (Oven Repair (including Ranges and Cooktops))
Frigidaire electric range temperature fluctuations (Oven Repair (including Ranges and Cooktops))
by faisalmali 15 years ago
Frigidaire Electric Range and Cooktop (Oven Repair (including Ranges and Cooktops))
by bboustany 15 years ago
Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by billfvib 16 years ago
1975 Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by BHERNANDEZ3 16 years ago
by Schnidly 17 years ago
