PITMAN
#1 Posted : Thursday, September 29, 2011 7:44:11 PM(UTC)
PITMAN
stove and oven elements quit working. clock and lights work. dealer went out of business.:mad:
#2 Posted : Sunday, October 2, 2011 12:49:06 AM(UTC)
Replacement parts for FRIGIDAIRE FES365EQA Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318271906.pdf
Often this is a power problem as the 240 volts feeding the stove top and oven elements have different controls.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker and the elements require the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
SOS - Frigidaire Electric Range not working (Oven Repair (including Ranges and Cooktops))
by Pete11 1/27/2015 8:23:19 AM(UTC)
Frigidaire Electric Range F3 fault code (Oven Repair (including Ranges and Cooktops))
by utahmom 3/31/2014 12:26:01 PM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
Frigidaire Electric Range - Oven just blew - Top works HELP (Oven Repair (including Ranges and Cooktops))
by Kris&Tara 4/3/2011 6:14:12 PM(UTC)
changing ECU in frigidaire electric range.. quick question (Oven Repair (including Ranges and Cooktops))
by larryk13 3/22/2010 2:52:24 PM(UTC)
Frigidaire Electric Range-- controller 'brains' (Oven Repair (including Ranges and Cooktops))
by larryk13 3/19/2010 7:52:08 AM(UTC)
Frigidaire electric range temperature fluctuations (Oven Repair (including Ranges and Cooktops))
by faisalmali 11/25/2009 4:23:09 AM(UTC)
Frigidaire Electric Range and Cooktop (Oven Repair (including Ranges and Cooktops))
by bboustany 11/7/2009 11:24:31 AM(UTC)
Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by billfvib 5/31/2009 10:54:38 AM(UTC)
by billfvib 5/31/2009 10:50:40 AM(UTC)
1975 Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by BHERNANDEZ3 2/2/2009 7:13:30 AM(UTC)
by Schnidly 5/23/2008 10:40:13 AM(UTC)
