Schnidly
#1 Posted : 17 years ago
Schnidly
Dear Sirs,
I own the above model Frigidaire, can anyone tell me how to check the dual element switch? Both the inside and outside burner comes on no matter which direction the control knob is turned. Also, can someone give me directions on how to replace the old switch with the new one, are there any concerns for me to understand before tearing apart the back panel of the range? Also, does someone know how to calibrate the oven? I dont have a thermometer that reads that high to calibrate with, any suggestions?
Thanks so much
#2 Posted : 17 years ago
According to your description of the problem with the dual element the switch is bad and does not need any further diagnosis.
In order to calibrate the oven temperature you have to have a good oven thermometer.
- The part number for the dual element switch is AP2141123
SOS - Frigidaire Electric Range not working (Oven Repair (including Ranges and Cooktops))
by Pete11 10 years ago
Frigidaire Electric Range F3 fault code (Oven Repair (including Ranges and Cooktops))
by utahmom 11 years ago
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 12 years ago
frigidaire electric range (Oven Repair (including Ranges and Cooktops))
by PITMAN 14 years ago
Frigidaire Electric Range - Oven just blew - Top works HELP (Oven Repair (including Ranges and Cooktops))
by Kris&Tara 14 years ago
changing ECU in frigidaire electric range.. quick question (Oven Repair (including Ranges and Cooktops))
by larryk13 15 years ago
Frigidaire Electric Range-- controller 'brains' (Oven Repair (including Ranges and Cooktops))
Frigidaire electric range temperature fluctuations (Oven Repair (including Ranges and Cooktops))
by faisalmali 15 years ago
Frigidaire Electric Range and Cooktop (Oven Repair (including Ranges and Cooktops))
by bboustany 15 years ago
Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by billfvib 16 years ago
1975 Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by BHERNANDEZ3 16 years ago
