electric45mike
#1 Posted : Thursday, December 20, 2007 12:29:45 PM(UTC)
electric45mike
Dishwasher starts & runs normally but never drains the soapy water out. It has run over 2 hrs. without shutting down. I open door, hit cancel & shut door and it pumps the water out & shuts down. Checked the water temp at 118 degrees which should be good. All the valves & pump seem to work okay so I wonder if the control board has a problem.
#2 Posted : Thursday, December 20, 2007 3:43:14 PM(UTC)
If the dishwasher did not switch to drain for such log time, the control board has to be replaced.
- The part number for the control board is AP3775964
- Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDP01FLSS1
Good luck.
electric45mike
#3 Posted : Thursday, December 20, 2007 3:46:59 PM(UTC)
electric45mike
Thanks Gene-that's what I suspected.
electric45mike
#4 Posted : Thursday, December 20, 2007 3:50:46 PM(UTC)
Keep me updated, please.
electric45mike
#5 Posted : Thursday, December 20, 2007 5:41:58 PM(UTC)
electric45mike
Gene,
I will keep you posted-I will have to order the control board. I noticed in one of your other threads that you mention tech sheets. Where can you find the for Kitchen Aid D/W?
Thanks,
Mike
#6 Posted : Thursday, December 20, 2007 8:28:44 PM(UTC)
Hi Mike
The tech sheets for your dishwasher.
electric45mike
#7 Posted : Friday, December 21, 2007 5:39:58 PM(UTC)
electric45mike
Thanks for the info Gene. I have ordered the part. S/B here maybe Wed.-Thur next week.
Mike
electric45mike
#8 Posted : Saturday, December 29, 2007 7:43:55 AM(UTC)
electric45mike
Gene,
I got the control board Thurs. & got it installed. The machine still runs over 2 hrs. but I was able to get into the diagnostics & the clean light started blinking 7 times, stopped & then repeated. I found a reference to this being the heating system so I ran it through with inlet water at 100 degrees & took several temp readings on the heating element. It never was above the water temp. I inspected the element & found a hole at the back of the element. I didn't pull the washer out & turn upside down to take resistance readings but just ordered an element, thermister & hi temp limit thermostat. Since I've got to pull it out to install the element, I'll check them out then. At least I'll have the parts if I need them. My thinking now is that if the heater was not working, the machine is trying to delay for heating the water with no success. Does that sound plausible? Parts should be here about Jan. 3-5. APP called yesterday & said the element washers were out of stock till next week. It looks like they provide the interior seal around the element legs so I was going to replace them just to be safe. I'll keep you posted. Thanks for your help.
Mike
electric45mike
#9 Posted : Saturday, January 5, 2008 4:20:23 PM(UTC)
electric45mike
Gene,
Just recvd heating system parts. Took element out & checked resistance & found it open. Checked hi temp limit thermostat & thermister- OK but replaced anyway since I had parts & D/W out. Reassembled & it runs & shuts down like new & even have some parts leftover.
Thanks for the help & best wishes for a Great New Year.
Mike
#10 Posted : Saturday, January 5, 2008 8:22:55 PM(UTC)
Mike,
I'm glad you were able to fix it.
Happy New Year to you as well.
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
Dishwasher keeps running as soon as door is closed (Dishwasher Repair)
by atamhank 12/22/2016 6:48:39 AM(UTC)
Dishwasher keeps Running (Dishwasher Repair)
by Edge27 2/24/2014 5:51:08 PM(UTC)
Dishwasher keeps running after going through Cycle (Dishwasher Repair)
by hodges_h 3/7/2011 12:15:03 PM(UTC)
Dishwasher keeps running (Dishwasher Repair)
by cfornecker 11/17/2009 5:18:55 AM(UTC)
Dishwasher keeps running & running (Dishwasher Repair)
by Steinmy 6/1/2009 6:01:05 AM(UTC)
dishwasher keeps running (Dishwasher Repair)
by bioislife 8/3/2007 5:18:59 AM(UTC)
