BALIPS
#1 Posted : Thursday, May 21, 2009 6:50:09 AM(UTC)
BALIPS
My washer all of a sudden yesterday would fill with water and wash my clothes but won't drain or spin.
I move the dial to the polsition where it should start the drain and spin cycle but it just humms...If I leave the washer on the dial rotates and starts agitating when it hits a certain spot on the dial otherwise it just has a slight humm until it gets to a position where it agitates.
Any suggestions?
Thank you!
#2 Posted : Thursday, May 21, 2009 12:25:18 PM(UTC)
Remove the front panel. Check the lid switch. Check the pump motor. Remove the hoses from the pump and check them for a clog. Post the results.
Here are the breakdown diagrams and Replacement parts for GE WHDSR315D5WW | AppliancePartsPros.com
BALIPS
#3 Posted : Thursday, May 21, 2009 6:45:46 PM(UTC)
BALIPS
The hoses look fine, no clogs. I removed the Lid switch and it rattles but I don't know how to check if it's working.
I also don't know how to check if the pump motor is working.
#4 Posted : Thursday, May 21, 2009 9:03:57 PM(UTC)
The lid switch has to be checked for continuity. The condition of the pump is visible as soon as you remove the front panel and run the washer on spin.
BALIPS
#5 Posted : Thursday, May 21, 2009 10:06:57 PM(UTC)
BALIPS
The pump looks fine...
it appears the lid switch isn't working properly...When I try to run the washer on spin it just hums loudly...and if I turn the dial it'll only agitate.
#6 Posted : Friday, May 22, 2009 4:14:34 PM(UTC)
Where this "hum" is coming from?
BALIPS
#7 Posted : Friday, May 22, 2009 7:17:52 PM(UTC)
BALIPS
It appears to be coming from the Timer...when I turn the dial and put it on the rinse or spin cycle it hums...when i put it on wash it agitates..
#8 Posted : Saturday, May 23, 2009 7:32:54 PM(UTC)
A humming noise from the timer... sounds very unusual. It might be from the motor or from the drain pump.
Have you checked the lid switch for continuity? Have you checked the pump and its hoses?
BALIPS
#9 Posted : Saturday, May 30, 2009 9:06:00 PM(UTC)
BALIPS
I was able to fix the washer by replacing the lid switch. THANK YOU
#10 Posted : Saturday, May 30, 2009 10:31:11 PM(UTC)
You are welcome. We are glad you were able to fix it.
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
GE washer won't drain (Washer Repair)
by denmor1991 10/5/2013 3:14:15 PM(UTC)
GE washer won't drain for large or normal loads. Only very small. (Washer Repair)
by joel_m_michael 1/7/2012 2:47:02 PM(UTC)
Ge washer won't drain (Washer Repair)
by dk2010 6/22/2011 5:49:16 PM(UTC)
by deplayerjr 7/16/2009 6:53:22 PM(UTC)
My GE washer won't drain (Washer Repair)
by Crsmom00 9/8/2008 3:58:23 PM(UTC)
GE washer won't drain Need help quick!!! (Washer Repair)
by meea 8/31/2007 10:07:33 AM(UTC)
