Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Got a Kitchen Aid Electric Range KFES530ESS2 2017 MFG Date. Had to put a new bake element in it, after putting the new genuine KA element, I’m not getting any heat from the element. I got 1026 ohms to the temp sensor (good), and no voltage across the bake element legs. Each leg to ground gets 118v. Does this indicate a bad board? Relay? I’m lost. Can just the relay be replaced on the board?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Based on the information provided, you are correct in that the oven control has failed. Unfortunately, the manufacturer does not provide the relay separately from the control W11088874.
