AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Less than two year old top load Maytag Washer Lid Hinge broken
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
If everyone on here is having the same problem then why don’t we file a class action suit?
Rank: Guest
Purchased mine in 2020. Replaced lid once in 2022. Now again in 2023
Rank: Guest
Originally Posted by: Guest  I purchased a Maytag top load washer on May 4, 2019 from Home Depot. 21 months later the left hinge broke, which is made of plastic. An appliance repairman was called and quoted $400 to fix the problem, plus labor. Of course, he charged for the visit he made. I have called Maytag's toll free number and researched whether or not there has been a recall on this model. There are other customers that have had the same problem, and Maytag is aware of the plastic hinges breaking, but there is no recall.
It is too early for a class action lawsuit; however the front load Maytag washers were having similar problems less than three years ago. Spending $400 plus labor to have this 21 month old Maytag Bravo top load washer repaired doesn't make sense. Are there any other customers facing this or do you have any suggestions other than purchasing another brand of top load washer or keep pouring money into this Maytag washer?
Thanks. I have had the same problem with this washer. Lid number 5 getting put on Friday. I. Up for the class action suit also. This is ridiculous. Purchased mi e at Lowe’s in 2018.
Rank: Guest
My has broken twice in 4 years… this machine is garbage. Maytag tried to blame it on me also. Mine also breaks at the left hinge.
Rank: Guest
Same issue here. What’s it take for there to be a recall?
Rank: Guest
This is the second time the left hinge broke. First time May tag replaced lid. Now the lid has broke again
Rank: Guest
Rank: Guest
Same thing, left side hinge cracked! Now the machine won’t work because the lid won’t lock. Frustrating!
Rank: Guest
I have this problem! Bought at lowes! Left hinge broken! Now machiene not locking properly!
Rank: Guest
I have the same issue. I called it will be over $400 to repair. The machine itself was $600. This is ridiculous and it should be repaired free of charge for a known issue.
Washer Repair
