KarenRae1067
#1 Posted : 15 years ago
KarenRae1067
Hi, I have a gas dryer that is not heating properly? When I start it, it glows red hot and it ignites the flame which only stays on for a minute or less, then it quickly shuts off. I have replaced the coils and now the flame sensor. Since I replaced the flame sensor the flame comes on more often, but seems to be shutting off too quickly to dry thoroughly. What other part may it be that needs replacing?
ApplianceJunk
#2 Posted : 15 years ago
ApplianceJunk
Even if it seems like you have good air flow out the vent I would check the blower housing around the fan for lint build up.
KarenRae1067
#3 Posted : 15 years ago
KarenRae1067
Thanks for the quick response. I will try your suggestion out.
Guest
#4 Posted : 2 years ago
Guest
Rank: Guest
United States
my dryer doesn’t work on the low setting, but I can heat it on medium and high settings.Why?
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 11 months ago
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 5 years ago
Whirlpool gas dryer (Dryer Repair)
by JoAnninWV 8 years ago
Whirlpool Gas Dryer heating intermittently, timer not working (Dryer Repair)
by christyhecht 8 years ago
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 8 years ago
Whirlpool Gas Dryer Takes Too Long (Dryer Repair)
by bijalshah01 8 years ago
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 8 years ago
Whirlpool gas dryer heating issues/gas smell (Dryer Repair)
by Houseforsaken 9 years ago
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 10 years ago
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 10 years ago
Whirlpool gas dryer only heats for the first 5-10 minutes of cycle (Dryer Repair)
by Peter Wood 10 years ago
Whirlpool Gas Dryer LP to NG (Dryer Repair)
by kyle_8888 11 years ago
Whirlpool Gas Dryer - heat won't stay on (Dryer Repair)
by tubegeek 11 years ago
by jeswon 11 years ago
by miller42 12 years ago
