Originally Posted by: mbkerk  I think I need this part...
W10190935
Joe, You have it in stock here! Any chance of a little better deal on it since I replaced a water valve (ordered here) that I did not need to? MB, Your on the right track. It's not that difficult a job to do, but you do have to be careful. Drop me a line at joem@AppliancePartsPros.com With some contact info and we'll go from there. :) :) :)
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Some 2007 and 2008 models (GS6NVEXSL01) of Whirlpool use a metering fill valve (2305225). They have stopped using this valve due to issues. Check your metered fill function on your water dispenser with a measuring cup. Mine was delivering 8 oz when 4 oz was selected. I had tried reducing the cube size but obviously couldn’t overcome the excess water fill. The time to fill should be about 7 seconds and mine was running about 15 seconds. I credit the appliance technician at our local repair service who tipped me off to this particular valve problem. Bottom line, check your measured fill before you change your ice maker if overfilling is your only problem. Good luck!
Rank: Guest
Bingo. Measured fill gives us 10 ounces instead of 8. Is there a fix for this? Ice maker is overflowing as well.
