peco
#1 Posted : Wednesday, May 27, 2009 8:37:59 AM(UTC)
peco
I hade a problem with the washer macine not draining at first, I took the Drain pump apart and found a cloth stuck in it. Cleaned the Drain pump out. It worked for one load of laundry until it had to spin and after the spin. After the spin the washer signal Ld (long drain). After the first load the tube stopped filling with water. What can be wrong with it now. it seems like the water is not entering the tube.
sidfink43
#2 Posted : Thursday, May 28, 2009 5:27:11 PM(UTC)
sidfink43
My guess, and it is only a guess at this point, particularly with these machines, is that the pump has been damaged. Take a look and see if you can determine its condition.
Here is the service manual, which should also help in your diagnosis.
http://adcxns1.whirlpool...4632a4/$FILE/8178010.pdf
Good luck, and let us know what you find out.
A Couple of Problems, Dryer won't Heat / Washer won't fill with water (Washer Repair)
by gregjbutler 2/11/2013 4:14:21 PM(UTC)
washer won't fill with water. (Washer Repair)
by mikeshawver 4/21/2012 9:51:25 AM(UTC)
by Brandonks 3/8/2012 5:39:24 PM(UTC)
by colleenrclark 10/16/2011 4:20:46 PM(UTC)
GE Washer won't fill with water (Washer Repair)
by Nikon23 10/13/2011 7:40:41 PM(UTC)
frigidaire front load washer won't fill with water (Washer Repair)
by tponcsak69 8/14/2011 9:29:38 AM(UTC)
by elrodjo 8/6/2010 3:58:05 PM(UTC)
by muleyhunter 8/16/2009 1:44:35 PM(UTC)
Haier Washer won't fill with water (Washer Repair)
by bealcli 7/9/2009 11:19:49 AM(UTC)
Dishwasher won't fill with water (Dishwasher Repair)
by Tru2Chevy 6/26/2009 7:41:16 PM(UTC)
woman in need of help washer won't fill with water (Washer Repair)
by lindavanzandt 11/30/2008 11:20:23 AM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
by gimpy54 7/1/2008 10:25:11 AM(UTC)
dishwasher won't fill with water (Dishwasher Repair)
by jhmorlang 2/6/2008 8:48:21 AM(UTC)
